Got around to replacing my truck's split tie rod end boots today. Used the OTC 7315A tool to pop the TRE's off the steering arms; went very smoothly.
Tools required:
OTC 7315A TRE removal tool (Tool_Topia had the best price)
Impact wrench, 19mm socket, flex extension (or 19mm box wrench or 19mm Gear wrench)
Pliers
Hammer
Small and mid size blade screw drivers.
Supplies needed:
Replacement TRE rubber boots (Trail Gear; ~$7)
New cotter pins (~35mmx2.7mm or 1 1/2"x1/8")
Grease to repack boots/TRE
Plastic safe parts cleaner
Paper towels
The only tricky part is attaching the new larger spring at the base of the boot. After cleaning, inspecting, and regreasing the TRE and packing the new boots with grease slide the boots over the shaft without the larger spring, the small spring on the top of the boot can stay attached. Once the new boot is in place you can then slide the new larger spring over the boot working it down around the edge in a spiral manner. You may want to burp any air or excess grease out of the boots before you put on the large spring.
The photos tell the story.
Tools required:
Pliers
Hammer
Supplies needed:
Paper towels
