replacement radiator 13BT?
I will pick up my repaired radiator soon.
My water pump is an Aisin, 10 years old or so.
Would you replace it since it is all out in the open with no fan or shroud?
When I have been in this situation, I have gone ahead and replaced the water pump. What are your plans on your thermostat?
The basis for my question was what I encountered last year on my FJ40. The water pump started leaking after ~8 years. Replaced it and on a test drive it started to over heat. What I found was the ~8 year old thermostat was bad. Upon removal, its visual condition appeared brand new after 8 years of use. All cooling issues ended with installation of the new thermostat.
Good luck
100% replace that. I just had a coolant leak, I’m still not convinced at all it was my water pump, but I replaced it because it’s a pain to get to later on.
I also would replace the thermostat, I wouldn’t take the lower thermostat housing off the block unless it’s leaking or really showing signs of it being crusty. I also replaced the radiator hoses which are still available.
Yep. I ordered a new pump.
Thermostat was already on hand.
Does the t-stat need the rubber ring that stretches around the circumference of its flange? I don’t see it shown in a parts diagram. There is just a plain old gasket shown.
Yes , needs the rubber ring. That’s what seals it. You don’t need any other gasket there.
Cruiser outfitters may have one, in ordered mine a few years ago from someone on mud, I’d have to look it back up.
13B-T engines do not have a rubber ring around the thermostat. Only a gasket sealing the upper and lower housings:
16341-56021
16341-56021
I found this from Greg, but I also remembered this from the past when I built mine as well and bought from someone on mud.
ToyoDYI show a changed part number:
16341-56020 for 11/1984-07/1988 (google shows paper gasket)
16341-56030 for 08/1988-12/1989 (google shows o-ring gasket even though EPC diagram shows the paper style)
The lower thermostat housing has 4 part number changeups in the 1984-1989 period and the upper looks to be the same through the run. If that means you can use either gasket style I dunno. O-ring style in mine when I've changed it in the past, so new 16341-56030 o-ring style is what I've put back in. Mines a blue block and 1989.
Yes on the gasket that is between the thermostat housing and head being the same as mentioned above.
hth's
gb
Mines an 11/88 so maybe that’s why I used the rubber gasket which has worked for 5 years?
Also from cruiser outfitters
Fits 3B/13BT Engine BJ4x/60/7x thru 08/1988 (and some later). 09/1988+ 3B/13BT uses RADOR56030 rubber ring on thermostat only.
hth's
gb
All the B engines switched to the rubber type thermostat seal in 08/1988. If your lower thermostat housing has a machined recess you can use the rubber type.
I will be paying $100 for mine to be resoldered.
Plus travel time and fuel to get it fixed.
Plus I'm buying a back-up factory rad from someone on MUD.
Hopefully you have better luck than I did. I had it tested and repaired when I first got it, and it lasted 3 years before it started leaking again.
That’s when I had to have a new one rebuilt with my old top/bottom tanks.
What’s the month/year of your BJ74?
