like this ?
like this ?
like this ?
What is the Part Number for this larger O-ring at the bottom of the By-pass tube in this Pic? Its not in the Toyota Part Diagram, only the 3 o-rings (90301-29006) are. Im confused... Beno?like this ?
like this ?
like this ?
like this ?
Thanks Beno.The three orings of the same size go on the bypass pipe. The bigger thick one is for the oil filler cap.
The schematic has everything you need to know about what is in the kit if you know the 1FZ-FE.
I'll make it easier for you.
This is what is in 04112-66036 (Valve Grind kit, 1FZ-FE: AKA: Head Gasket kit)
1. Head Gasket
2. Injector orings and grommets
3. Fuel line gaskets
4. Throttle body gasket
5. Exhaust Manifold gaskets
6. Intake manifold to head gasket
7. Upper and lower intake gaskets
8. EGR valve to intake manifold gasket
9. EGR pipe to head gasket
10. Fuel filter banjo bolt gaskets
11. Valve cover gasket
12. Spark plug tube seals
13. Valve stem seals (both intake and exhaust valves--24 total since it is a 24 valve engine)
14. Water outlet gasket
15. Thermostat gasket
16. Timing Chain tensioner gasket
17. Water bypass outlet orings (3)
18. Exhaust manifold down pipe donut gaskets
19. Air injection tube gaskets (for 1993-1994 trucks)
20. Gaskets for the cylinder head screw plugs
21. Dizzy oring
You need to add: water bypass tube gasket, oil cooler gaskets x2, oil cooler cover gasket, gaskets for the oil cooler plug and relief valve, FIPG for the half moons. Everything else that you add depends on the scope of the work you are doing and the scope of the plan.
Beno,
Are you still a source for the parts you recommended in this thread? I have a 1993 FJZ80. Head is off and looking gather parts for reassembly. Along with the head gasket kit also looking for intake and exhaust stud kit, and heater hose kit and any other parts you may recommend. Thanks.
has anyone used this kit from wits end?Next best thing?
80 Series 1FZ Complete Head Gasket Kit
80 Series 1FZ Complete Head Gasket Kit (HGK-1FZ)absolute-wits-end.com
Beno,
Could you please quote me some parts shipped to 98387?
I own a 1994 FZJ80
04112-66036 head gasket valve grind kit 1qty
15725-66010 oil cooler gasket 1qty
15785-66010 oil cooler gasket 3qty
15134-20010 oil pump gasket 2qty
15134-17010 gasket 1qty
90311-99006 rear crank seal 1qty
19127-66020 distributor cap gasket 1qty
90301-09173 tranny dipstick o-ring 1qty
90950-01803 plug hole (flywheel) 1qty
90179-10070 exhaust down pipes nuts 4qty
90126-10006 exhaust down pipes studs 4qty
90179-10037 exhaust manifold to head nuts 13qty
90126-08008 exhaust manifold to head studs 13qty
56121-60100 windshield gasket 1qty
28226-66060 starter kit 1qty
28226-72010 starter kit 1qty
28235-54380 plunger 1qty
28175-54380 gasket 1qty
90099-14064 starter o-ring 2qty
Thank you!
it does in deed. lol lol lolI hear it causes flaming radiator fumes![]()
