- Thread starter
- #161
LT, with all due respect, I've seen a lot of pitted electrical contacts. Pull your ignition switch apart and post up pics. You can slide over an electrical contact and have pit/arcing, or momentarilyy push an electrical contact and have pit/arcing.
It's exactly the same problem, causing the exact same intermittent and failure. BTST x too many. You do not need to replace the ignition tumbler assbly, only the POS plastic insert with the electrical connections.
No sugar coating. And Beowolf, the 93 switch I replaced had everything *and* a smurf doll hanging off the key ring. Excellent point on that... As one of my shop buddies said with his thick polish accent, "use the ignition switch to insert your key, not as a key hook for your pocket trash"
ST
Sumo, don't forget to post them pictures of old worn, pitted contacts. Thanks.
The ignition switch has not arrive yet. Though, I know its on the way, because payment just cleared yesterday. Hopefully, it'll be in by tomorrow for a Saturday morning install.
Ron
