looks different from the LX450 switch, no key retainer solenoid on the Land Cruiser?
https://forum.ih8mud.com/showpost.php?p=1514519&postcount=12
You called it. Props!maybe I should have had a bet on the igintion switch being the problem.......
Is there any way to pull the switch and clean/maintenance the contacts?
I beleve Im next on the list to do this.
It seems Im rolling the dice right now , sometime start sometime not.
Thanks for this thread.
ken
so is there any PM that can be done to the ignition switch to help its life expectancy? clean and lube? dielectric grease?
If the switch was easy to ge to like a C-210 or 180 (ac talk) I'd say clean that sucker.
I have never worked GA but I have seen the panels and see your point.
I have been following this thread and have found no solution, I have replaced;
Starter
Battery cables (both positive and negative)
Fusible link has been cleaned out
Ran a second ground to the block
The only thing left is the ignition switch but I have remote start and it completely bypasses the switch so it should not be an issue. I have a fairly new battery and it reads 12.2V
When I try to start it the lead wire to the starter only reads about 9 to 10 volts.
Once the truck is started it fires up like a champ but it causes an issue when it has sat for a while. My only thought would be my alternator is providing enough juice back to the battery.
Give me some thoughts,
