Replace Oil Pump?
The gear that drives the oil pump and power steering is just sandwiched between the crank pulley and crank. There is no key way on the crank to stop the gear from spinning on the snout. The only thing stopping it spinning is the friction from the pulley being tightened to just over 300 ft lbs.
^^^ This.
The wire/connector failing at the oil pressure sender is also somewhat common. But, you would think that a pro tech would check that before taking the oil pump apart,,, or,,, maybe not?
Started assembling it, but need to know what some parts are from, for example the:
spring
oil sender unit?
a nut with a copper washer
and the unit next to it
the bracket at top
^^^ This.
The wire/connector failing at the oil pressure sender is also somewhat common. But, you would thing that a pro tech would check that before taking the oil pump apart,,, or,,, maybe not?
He definitely should have checked oil pressure before condemning the pump. Or at least used common sense.
The bell looking thing is the sender. I would suspect the spring goes in the housing and the bolt with a dished out portion and copper washer is what holds the spring in the housing. The unit next to it would go in the pump with the spring on it. Looks like a pressure relief.
starte
Thank You...how about that bracket?
That bracket looks like the one that bolts under the bottom oil pan and has the oil level wire and or crank angle sensor wire run through that hump in it.
That bolt with the washer and the spring look like they came off the side of the oil pump housing. Could also be from the oil cooler cover. On the side of the block above where the oil sender screws in there is an aluminum cover. Check the top of it it has 2 bolts like the one in your pic and there should be a spring like the one pictured in there too. Better make sure the little piston is still in the cooler cover too.
I started to remove the radiator and noticed the anti-freeze was red is that a for Toyota vehicles type of coolant?
The OEM Toyota coolant is red. Don't mix it with green. It will get sludgey. If you decide to switch to green (cheaper and available at any car parts store) be sure to flush all the red. Flush again, then flush some more. (You may want to follow that up with flushing it once more.)
Well there was absolutely nothing wrong with the LC other than a faulty dash gauge, i used a MATCO mechanical oil pressure gauge and have about 50psi cold and when i revved it it jumped up to 90 with new pump.
Replaced oil pump, crank seal, cover seal and belts,installed new sending unit all from Beno. Everything works on this thing I mean the AC, cruise, mirrors LC is in xlnt condition from what i can tell.
Ordered a Speedhut oil pressure gauge for it, I guess I did score on this.
Nice result!
The PO is probably all,
:bang:
