Replace Oil Pump?
Temecula California
I'm looking at a 1997 FZj80 with a broken oil pump. The motor has about 167,000 on it.
The owner is asking $1,800 for the cruiser. How hard, is it to replace the oil pump. I can find articles on replacing the gasket, but I have yet to find one detailing the replacement. Thanks so much.
Chris
It's part of the front cover, so pretty big job. How was it damaged, have done a bunch of reseal jobs and have never seen one with wear.
The owner stated he was driving down the highway and lost oil pressure, pulled over and then was towed to a shop.
Stated something to the affect of "sheared shaft"..........was what was passed on to me.
More likely, the front crank bolt is loose?
The front right cover has been pulled, $300 latter his mechanic told him about the pump. I also wonder what else might be broken, and where the broken part is now. Should I stay away from this one? I very much appreciate all the advice. I have no history with this motor and it is completely new to me.
I just bought a similar situation 93 190K miles with factory lockers for $1,500 this weekend. I have not been able to diagnose anything yet but the PO told me the same thing (ie. lost all oil pressure and heard a knock so he shut it down and parked it). I'm somewhere between confident and hopeful that it is not a major issue and can run again without too much expense. Either way, I at least have a good parts rig for my 94 with lockers.
I just can't imagine an oil pump 'breaking'. There is no shaft to drive it, it's geared directly off of the crankshaft. The crankshaft mounted drive gear is held down by the harmonic balancer bolt. The oil pump itself is only two pieces, the impeller shaft and a rotating collar. Not much to go wrong. If something very solid and metallic made it past the intake screen and sucked into the pump, it could break, but then you have to wonder where the very solid metallic piece came from. I also believe there is enough clearance for parts that will pass through the screen to also pass through the pump.
Also, you only have seconds to get shut down @ zero oil pressure before doing major damage to the bottom end of the engine, dry bearings toast quickly. The PO would have to have been very alert to get it shut down before damage occurred from no oil pressure. If you buy it plan for a rebuild or motor swap, maybe you'll get lucky, but I doubt it.
Some pics of the broken part would be helpful if you can get them.
I bought this from the OP, I finally got
around to looking into the repair and I purchased a oil pump from @beno, as you can see from the pictures the original pump the new pump are exactly the same condition should I put it back together and start it up to see if there are any bottom end noises and oil pressure.
The engine is not seized.
Those gears look good, if the pump housing also looks good, would put it back together. Most oil pressure, and/or power steering loss is from the harmonic balance bolt being loose, it needs to be tight, like 304ft/lb tight.
My sender took a dump about two weeks after I got mine home. One minor heart attack (it seemed like it) later, I jury rigged the sender to work again and we're good. Since that time, I've been meaning to replace it, and it occasionally goes T/U, but I just renew my rigged "fix" and drive on.
During a recent head gasket adventure I was standing in the engine bay I broke my oil sender wire and didn't know it. And when I did start it after the head gasket I literally freaked the hell out.No oil pressure and no brakes.fixed the wire with solder and dug the mud wasp out of my vacuum nipple on the brake booster.my nerves can't handle another rebuild any time soon.
