Removing the Roof Rails
I’m glad I found this thread or I would’ve definitely broke the nut plate. Are you guys trimming the yellow tabs so that the spacer sits flush? Or do the yellow tabs compress when tightening the mount?
I left the yellow tabs as they were and I didn't have a problem with the spacers sitting flush.
What thread sealer / loctite/ silicone are you guys using to waterproof the bolts when permanently deleting the rack? I’ve had the dealer take it off for me in the past and I never asked. Now I want to do it at home but want to prevent rain from getting inside.
From the advice of others on this forum, I used: Amazon product ASIN B000HBM6NG
No problems since I installed a Prinsu rack 6 weeks ago - but I live in California where it doesn't rain, it just burns :(
I plan on removing my stock rack from a 2015 LC so the LC will fit in my garage, can anyone confirm that these parts will fit a 2015 LC?
75596-0E040 - Cover
63185-0R010 - Bracket
90119-08C47 - Bolt
When I search online for parts at Conicelli Toyota it says that these parts won't fit my LC??
I spoke with Conicelli Toyota and they said the correct bracket for a 2015 LC is 63185-42020 and that the cover and bolt listed above will fit.
Oh man....wish I found this thread before....fortunately the bracket i broke is the 2nd one on the LX and not needed for my victory 4x4 rack...silicone it is.
I lost some of the screws. Not the short ones referenced above...the longer ones that goes in the yellow threaded holes. does anyone have the part number? is this a special type of bolt? or i can get at hardware store with some rubber washers.
Hardware store... it's just a standard M8 thread, 20-25mm long is plenty. Add a rubber washer and a little silicone, good to go. :cheers:
