removing cats
SoCal
I'm was thinking about setting up my cats to be removable for off-roading, just welding a flange on either side and having a piece of strait pipe w/ the same flanges to replace it, does anyone know if this will throw a code on the ecm?
why would you want to do this?
if it's for clearance, why not simply cut the cats off, turn them 90 degrees, so they're tucked up and away, then weld them back on.
yes, you'll likely throw a code...if nothing else...
What year is your 80? If its 93-up you will throw a code. If its 91-92 with a 3fe then gut a chop away. Unless your in CA I would just take them off and not worry about switching the cats in and out. It seems like and exhaust system that is so interchangeable would leak a lot.
If you want it to be interchangeable you could put a dump box like they use for muscle cars :grinpimp: :grinpimp: :grinpimp: that would be funny but I doubt it would work that well.
It's a 97 so I guess removing them is out, I like the cut and turn idea, I'm just wanting to keep them from getting bashed up by a rock, thanks for the replies
If you are worried about cats getting banged up, why not get sliders that protect them? You should be worried about the bottoms of your doors anyways.
If you want, you can remove them and run an O2 Sims :)
You can make one easily using an old 555 timer chip :cool:
Basically, it creates an oscillating circuit that makes the ECU think the O2 sensor is working properly :grinpimp:
Only difference is that it will be running in closed loop mode from the moment of startup, so there's no initial open loop warmup (not a bad thing, especially for those with the high rpm cold start gremlin)
You can also have it programmed out, but I'd much rather spend $3 bucks and build my own sim than $1200 on a new programmer ;p
Rick
Rick, how do you build a sim?
Here's a basic diagram:
All of the parts needed can be found at Radio Snack for about $15 bucks, but I can get everything for about $3 bucks at my local electrical surplus store (www.skycraftsurplus.com)
Resistor values will vary from vehicle to vehicle, but here's a value list for a 2JZ Supra engine just to give you an idea:
http://www.mkiv.com/techarticles/oxygen_sensor_simulator/
Figuring out the correct values for the 1FZ-FE would be a simple task with an Ohm meter, but I'd say it'll be fairly close to the 2JZ values :cool:
Rick
Hi there, I'm a newbie here and have some questions. I just sold my 1989 4X4 Toyota Pick Up and purchased a 1996 Lexus LX450.
So far I love it! However the cat is tripping the check engine sensor.
What does the cat do?
Do I need it?
Is there any benifit to taking it out?
What is a 555 chip?
Do I need it?
What is a 555 chip?
Did you actally get an MIL for cat failure or just an O2 sensor? (cats rarely fail unless you've been running uberly rich for a long time)
The cat is basically used to reburn the exhaust gases to make them less toxic...
You don't need it for the engine to run (most other countries don't even use them), however, if your state requires a yearly inspection, you will need it to pass...
Unless your rig is FI or juissed, the performance gain will be very minor (not worth doing imho)
It will also be much louder than stock....
As for the 555 chip, I'll let wiki handle that one ;)
555 timer IC - Wikipedia, the free encyclopedia
O2 sensor. I was told when i purchased it that it was the cat.
So, I can get a cat and fix it . . .
Will I need to have the computer reset or will it do it on it's own?
Will any aftermarket cat work? or should I get some particular one?
rules and regulations vary from state to state. it might help to tell us what state you live in and what the code is (that's triggering your MIL)
OK. I bought an o2 sim and installed it last night. And the light was off, but . . . now it's back on.
I cut the wires to more easily work on the plug and then re-soldered the blue and white wires.
However, I faliled to re-solder the power wire, because it and the sensor wire are black and I couldn't tell the difference.
Also, I didn't know if the blue wire or the white wire was the actual ground, so I hooked the ground for the sim up to the white wire.
Anybody know what wire is what?
Or what the 12v power wire does? Is is necessary to avoid a heater ground error?
Any help would be much appreciated!!
