Removing 1F engine with transmission
Long Island
As part of a frame swap, I'm about ready to pull the engine, tranny, and transfer case connected. I have everything stripped off both frames. I planned to lift everything up, carry out the old frame, carry in the new frame and sit the engine back down.
Does anyone know the weight of all of this connected. I read the engine and bell housing is north of 700lb. What is it with the tranny and transfer.
Also the F does not have any lift hooks. Can anyone suggest proper lifting points?
Thanks!
If I was to guess, the transmission and transfer case added about 150-200 lbs. The transfer case alone is 95 lbs. The F does not have any lift hooks but you can use four head bolts to lift the engine out with. Just be sure to torque them back when you are done.
upload_2018-6-14_8-52-33-png.1723011
3speed trans and transfer less parking brake is 130#. Getting ready to ship one. ;)
When I did it, I rolled the new frame on wheels and axles under the lifted engine and transmission. I found it rolled much better than the engine hoist. I had a beefy hoist, but with it extended out, I was able to watch the boom flex under the load.
Afterwards I lifted the tub upwards using the factory roll bar and rolled the frame and drivetrain under it.
Here is my deal, with the engine to parking drum, I had an issue with the length of the boom, at the 1 ton setting, my 2 Ton Pittsburgh can barely grab the back of the motor without bumping the hydraulic ram into the frame, and the 1/2 ton setting will tip the hoist.. I used a load leveler, and put most of the weight on the back of the head by the last exhaust valve, which is why I couldn't really use the 1.5 or 2 ton settings, IIRC.
My frame was not stripped on my '75 2F 4 speed. The offset transfer case twists the whole thing quite a bit. With weight off the engine, and at some point thru the move I removed the motor mount bracket on the driver side bellhousing, its path is in the way of the steering box half way thru the move, and at that point, there isn't much clearance on the passenger side for the transfer case.
There are engine lift hooks for the F engine. Mine has them. I pulled the engine, tranny and t-case all together using a Harbor Freight cherry picker in the 1 ton configuration. Had no issues doing it, other than the cylinder kept leaking down due to the very cold weather.
My F engine also has lifting hooks.
Head bolts are 13mm or .512"
1/2" is .500".Those lifting rings should fit.If not it won't take much with a dremel or die grinder to open up the holes.
