Removed front drive shaft
maneuvering when towing on a hard surface I like low gear open diff. In the snow or gravel or sand I like cdl on to disable the abs then reach spead and turn cdl off for an open center diff with no abs.
I'm not overly enthusiastic about the way the cruiser handles with out the front drive shaft in, but I've run mine that way for close to two years. I got so worried about the viscous coupler that I don't have that I recently tried to sell my spare x-fer case.:D
What is to be gained by removing front drive shaft? the axels are still going to be turning. Is it really a significant power or economy gain?
Just curious.
My guess is that it is probably more for people who have not properly addressed their front driveshaft following lift, and therefore have driveline vibe to the increased angle without a DC shaft or other efforts to address increase in pinion/t-case angles. I don't really know as I've always driven with a front shaft.:meh:
That's the primary reason for doing this mod I think. Also, not having a front DS does make the steering a tad easier and it might make the 80 more "peppy" - according to the butt dyno anyway!
It worked well for me when I had a universal go on the road.
Is there a way to tell for sure that the center diff is locked after you pull the correct fuse?
Yes.
Lock center diff. (if you have the CDL button on your console) and drive away.
I drive with my front drive shaft off at all time and put front shaft back in only when wheeling.
Beno while combing the forum for my answer I'll ask you if you don't mind what is the furthest you've driven without the front DS. I ask cause I'm leaving for GSMTR next week and was considering leaving it off for the 700 mile drive up there and put it on when I make camp. I've run around locally without it many times but was having second thoughts on that kind of drive with the CDL on :hhmm: your input is appreciated.
As long as the center is locked I see no possible damage. It will handle differently, ABS wont work, I have driven mine long term with a shaft out and zero issues.
Thanks for the feedback :beer: the ABS won't be much of an isssue with the cruise set going down the HWY so I think I'll run it up there without it.
Thousands of miles....
There is nothing wrong with pulling your front drive shaft and driving in 2WD. It's worked on every other Land Cruiser before the 80 series.
I just did a 2500 mile trip and did it with unlocked hubs and no front DS, CDL engaged for about 1500 of those miles--different speeds, terrain, etc. No issues.
That said, I am going to a PT xfer case to be in a more true PT situation where I won't have to uninstall the front drive shaft.
