Remove the front sway bar.
north vancouver
Hey guys..
I did a search on sway bars, found lots about quick disconnects, but very little about removing the sway bar completley.
I was wondering if that can be done, or what the prevaling thoughts are on that.
i have done that on my jeep, but its alot smaller and lighter.
The reason for this is its only a wheeling cruiser, so i dont really need the stability in the city, and just thought i dont really need it.
any thoughts.
thanks
scott.
I have removed both of mine. Defineatly more body roll.I have just gotten used to driving without them. I daily drive and wheel it.
Trail removed both of mine also. With J springs there's definitely more body roll, I'm planning to put them back on and fab up some disconnects.
I removed both of mine about a year ago and haven't regetted it once. Although it will be debated, I definately noticed improved articulation and since I don't do any freeway driving I don't feel unsafe without them.
How much more articulation does it actually give? I've seen a few posts that make me think it's not much at all.
Is that because an 80 already has pretty good articulation?
I'm wondering because there is a somewhat local organization "Just Runs" that for certain trails, requires a disconnect. Steve, you mentioned this group when we met last and I'd like to do some of the runs but I don't think I really need a disconnect.
Interesting. What is the organization's rationale for requiring a disconnect?
-B-
Having ridden around in lifted 80s with no sway bars, I think they are dangerous on the highway. The body roll is already fairly severe in these trucks, and add speed and no sway bar...... Fool yourself if you wish, but they are a rollover waiting to happen. I strongly recommend you keep at least the front intact.
I think they are fine on the trail disconnected .
I simply completely unbolt mine on trail day (often at the trailhead), and then bolt it back up when I am back home.
I will not rock crawl with the front connected because it takes out the brake hard line when you rip it off.
As I said, this topic always leads to debate:D. For most people, removing the swaybars doesn't make any sense. If I were to try to put a number to the benefit, I'd say maybe 5%. But as many others have stated I think that the lack of swaybars also gives a better/smooter ride off road.
Actually the other group I mentioned was adventure4X4.net. They are a very diverse group from stock to pretty well set up rigs. They have a slogan slightly similar but have no such rules.
I have heard of the group "Just Runs" but that's about all.
This has happened to quite a few here on Mud as well.
All in all, I don't feel as if there is any more body roll with my 6" springs and no sway bars than there was when my rig was on soft stock Lexus springs with sway bars. I don't feel it's any more dangerous than say, a fully loaded roof rack. But you know what they say about opinions:)
