Remove OEM Seat Covers?
I have and it wasn't fun. Get some hog ring pliers if you can. It will make removing them much easier. You can also us needle nose pliers and a screw driver.
https://forum.ih8mud.com/showthread.php?t=100064&highlight=seat+covers
Remove seat. Then the brackets and backing. You will see where the rings are attached to the frame.
Just take your time and do not try to force it..
ttt Aatlas1x?
I hate seats!! Even the rears as I have to assemble a set tonight.
Use a heat gun or dry to soften the vinyl and silicone spray to get the foam not to stick while installing them.
I would rather pay to save my fat little fingers, but silicone and heat are your friend, dont melt them that is!
i think i'd spend the couple hundred bucks and get new covers.
$400 minimum from a local shop, and I'd strongly prefer OEM anyway. I didn't like what the SOR $230 ones looked like after they wear in. I do, however, like the way my 29yo passenger's seatback looks.
Do you have a seat you can practice on? That would be the best way to see what makes it tick on the inside.
If FJResto can get it off, I'll probably bring it to a shop to have it reinstalled. Once I have it in my hands I can tear into my driver's seat without any worries, since it's already all ripped up. If it looks really easy I may do it myself, but I need some new foam so the new cover has good support and doesn't just rip out again in a year.
If this works out I'll need one more seat bottom cover. The back of my passenger's seat is good.
It's no big deal to get the seat covers off, or move from truck to truck. Hog rings are hog rings...anything will cut em off. If i'm in a hurry I use a rotary cutting air tool, if not, a pair of diagonal cutters. The only thing you have to fear is that old vinyl is not always supple. If you want the cover intact, do it in a warm environment. I've sold lots of good used covers since I put new upholstery on every time. One banana job. Hardware stores have em, along with hog ring pliers for installation.
