Removal front d/s
I've got mine out, drove 500 miles a couple weekends ago, noticed no improvement. Of course I had seven bikes and a large roof box on the truck. I'm still turning the whole front axle, so I don't expect to see a difference, unless there's significant drag from the front driveshaft joints. There was, that's why mine is out. It's got new joints in it, waiting for me to have time to reinstall, eight bolts might take me ten minutes.
Do you have locking hubs on the front?
Negligible. Good friend of mine removed his for a trip from Utah to California. He also installed manual hubs. He noticed a 1-2mpg increase. If you had to buy hubs and a CDL switch, I doubt you'd offset the cost from gas savings.
Of course, your truck won't move unless you lock the cdl...
-Spike
I can see the Pirate thread now: "Mudders gave advice that burned up my VC!! :( "
Kinda on topic, Kurt of Cruiser Outfitters had a truck in recently that had had front DS damage in Moab. A shop there pulled the DS and sent the guy on his way, no CDL switch, 300 mile drive back to Salt Lake City. Amazingly the VC held up, no apparent damage.
Center Differential Locker.
-Spike
-Spike
Oh, that :D. I have a CDL switch in the basement, my brother salvaged it from my 40th. Hardly seems worth installing in my unlocked 80.
I will say the truck seems smoother than I remember either of my trucks running, without the front driveshaft. Maybe it just gradually got a vibration, and I don't remember how smooth it used to run. Hopefully I'll get it back in and find out soon.
So now I'm Kornfuzed also...
If I understand this correctly, an 80 CAN be driven with the front drive shaft removed... If the center diff is locked.
Would this be correct? Are highway speeds ok, and what kind of distances are acceptable? 1mile-100miles?
On the other hand the center diff viscous coupler will be damaged if driven unlocked with the front drive shaft removed?
A clarification on this would be very appreciated as my 80 has developed some funky vibes that I would like to isolate before McGrew and being able to test drive it with out the front driveshaft would be helpful. Found one bad ujoint in the front shaft but will not have a replacement until thursday so will not know if it was the sole source of vibration until replaced or driven with out front drive shaft, but was not sure the 80 could be drive at highway speeds with CDL locked and front shaft missing.
CDL locked, no front DS = good to go.
No CDL switch + put in low, pull CDL fuse + go to high + pull drive shaft = good to go
No CDL + no front DS = possible Viscous Coupler damage in the t-case
Correct.
Essentially any speed, indefinitely (years even...).
Will likely be damaged. Definitely not a good idea.
The VC is similar to a clutch, like two friction plates. In theory, with the resistance of both axles, the friction is controlled and equally distributed front and rear. Without one of the driveshafts present, that side of the VC would be able to spin freely without resistance, going fast enough to burn itself up. The truck Kurt had was an interesting lesson, since in theory the VC should have been toast but appeared to be fine. It hasn't been opened up to see if the friction material was worn thin or what effect it had on the VC.
My VC/CDL lesson came in my driveway when I removed the rear DS to replace the u-joints. I hadn't thought about the slope of the driveway and figured the front axle would hold the truck in place. I was wrong, courtesy Mr. VC.
So how'd you lock your center diff. when you pulled your driveshaft? The "put it in low then pull the fuse" trick?
Yep. I hauled a big trailer daily working my construction side job with the 40th, used the CDL switch nearly every day. Don't need it even once a year on this truck, so I use the fuse.
And yes, you can drive in rear-wheel-drive or front-wheel-drive indefinitely by locking the diff and pulling one driveshaft. You won't have antilock brakes, or all-wheel-drive. I spent the last month driving in 2wd, took some long highway trips.
If you're having vibrations and a driveshaft seems bad, take it out. A pair of 14mm combination wrenches are all you need. Maybe a hammer to break the fasteners loose. Hit the threads with penetrating oil the day prior if you're really smart. But mark the ends so you can put it back in the same orientation. And note that the driveshaft is telescoping, and will come apart, and you really want to mark the two sections to get them back the same way. I just put mine back in with new joints, much better.
What about FJ80's (i have a '92)? You don't even have to worry about the VC since they have the older tranny right? And since the front axle is still rolling, through the wheels, then everything still gets lubed okay right? I was thinking about taking my front DS off to rework all the joints and have been wondering this. Sorry if its kind of a dumb question.
