Gday all,
Took in my FJ60 over the pits to get licensed but it failed on a number of items. It's late here now but I'll post photos of the leaks tomorrow for some input/thoughts from those more experienced.
In order on the govt issued white slip of pain:
1) Rear differential leak and play - photos tomorrow
2) Oil leaks from gearbox and engine - photos tomorrow
3) number plate lights not working, upon inspection the right hand side globe mount is missing entirely.
4) window washers to operate. I press the switch in the cab and I can hear the pump start but no water flow. I'll pull the reservoir tomorrow and check for sediment buildup causing blockage. Any tips on removing this from people that have done it prior? I'd like to avoid breaking fiddly plastic bits.
5) Shackle bushes front and rear - I intended to put
6) Wheel bearings need adjustment - I'll find a youtube video on how to do this
7) brake pedal hard, my Haynes book suggested a restricted brake line from master cylinder might be the cause. Any tips on fault finding this?
Serves me right for buying a truck sight unseen, but with such a clean body I just couldn't pass it up.
