refurbishing a '72 windshield wiper setup
The Intarwebs
anybody know of a good place that does wiper motor/setup restos? i thought i had heard of a place or a shop that sells new ones but i cant find them anywhere.
i have a guy lined up to look at it, AATLAS1X, who does heaters. he hasnt ever done a wiper setup though, so i just want to see if anybody else has done them before or knows who might do a good job...
for the top of the windshield frame, '72 vintage. i want them cleaned and restored!
That is most definitely a DIY. I did one and I wear slip-ons to avoid tying my shoes. Clean all the mud-hard grease out of the gearboxes, replace with fresh, lube the cable, wirebrush and paint the motor. Try to preserve the gaskets, but new ones are not that hard to make(or $OR them)
:beer: :beer: :beer:
Ed, can you explain the operation of the return wiper to top switch to me; is there something that pushes on left side of the switch? my cover is missing, and the switch will function if I press a finger on it, but not without? Not that it matters much in the AZ desert ;) but I just would like it to function properly.
Claudia The wiper stop is controlled by a cam that opens the circuit when the wiper is at the top of the windshield. This circuit has power when the ignition switch is on. The other ciruit only has power when the switch is on. It keeps the wiper running in the open circuit spot on the cam and keeps the wipers working. If you can push in the points in the controls at the wiper motor and it only runs while pushing it sounds like you have problem in the switch or your wiring. If you can pull the connector apart at the wiper motor and with the ignition switch on see if one wire has power all the time, then check to see if you get power to another wire when the wiper switch is turned on. If you don't get power when the switch turn you need to find out why, switch or wiring. If you still having problem maybe I can find time before the next time it rain to help you out. I also have spare motors but I doubt that's your problem.
John
Found this link several years ago and talked to them. Seemed like nice folks. Never did send my wipers out, but will if I decide to use the '40 as a DD and use in during the winter.
http://www.walshwiper.com/pages/main.html
John,
thanks for the reply.
The wiring to the wiper motor proper is fine and motor works. I also soldered on the one wire that had come loose from the stop switch; when manually touching the blades of the switch to its bottom, the wipers will wipe and go to the top of the windshield (correct, switch hot with ignition). To me that means, the switch basically is working and wired correctly. I just can't seem to figure out what would make the metal blades of the switch touch the backing plate (except physical force of my finger).
Of course, I am now in NE and have no pics or way to test.
https://forum.ih8mud.com/attachment.php?attachmentid=52749&stc=1&d=1137523299
stole this pic from Ed in an earlier post
what is the position of the blades relative to the red half ball while the wiper is actually wiping? what moves against what to stop the wiper in the return position? I have a lot of gunk in all of this and need to know where cleaning would really matter :hillbilly:
I have never had to work on one of these motors, I have rebuilt a few of the earlier TNK wiper motors and rewired a few of the 75 and later wiper motors. That red ball it part of the cam. It will feed power to the wiper all the time the ignition switch on except for when the wiper hits the top in it's off position. If the wiper switch is on it will feed power during the off position keeping the wiper moving. The only reason for those points operated by the red ball is to get the wiper to stop up and out the way. If you make contact with the points and the wipers run and then stop out of the way with the wiper switch on chances are good you have a problem with the switch or wiring for that switch. Just cause you can make the motor run by pushing that point in doesn't mean the switch circuit is good. Remember you have power up to the wiper even with the switch off.
John
