Redneck Shackle Issue
Dallas, TX
I have hated my shackles since buying my 40 a few months ago. They are about 7.5" bolt-to-bolt in the rear and stock (2.75") up front. The bushings, or what is left of bushings, are shot. Zero flex. I am running 33x12.5 and don't have a lot of clearance.
I want to replace the shackles with some decent ones. However, what should I do about the difference in length? The 7.5" is extreme, yet the front is stock. Re-arch springs? I'll post some more pics once my star takes effect.
You really can't afford more flex, given the size of your tires. I would think the best option is to run 31 inch tires, new poly bushings and stock length shackles. If you want to run the bigger tires, then a lift suspension is the only answer. The OME in particular, is well engineered, and will come with the springs, shackles and shocks. It is designed to run 33 inch tires. The cheapest option is number 1.
The really cheap option, would be to paint your roof white. It won't ride better, but it will look more like an FJ40.:D
new rear springs. The vertical shackle must ride nice. Mine rode horribly when they looked like that. Keep an eye on the for sale board, lift springs show up in there when people go SOA. You could do an add a leaf, but when you are all done (leaf, center pin, new ubolts, shocks) you could probably have done new springs.
Tires are pretty cracked and in need of replacement, but I would like to stick with 33".
I am leaning towards spring replacement.
I need to measure the difference in arch between front and rear.
Is it odd to have stock shackles up front with monster shackles in the rear?
Thanks projekt, I like the few hundred pounds of ride softner...
Replace the suspension ome, hfs, whatever you fancy . Springs and bushings are shot. With that rim/tires your still going to have cleance issues with the rear fender.
I have some 2.5" lift springs that I don't need. No idea what brand. They came from another board member. If interested, give me a pm. They clear 33s no problem.
Read Mark's tech article in the last 2 issues of Toyota Trails. There was an article on shackles that prompted me to ask a question about mine which was published in the next issue. I endes up making my own that are much stronger and cheaper than any I could buy. Thanks again Mark!
I would probably get rid of all that and go with new springs and shackles of your choosing. Those long shackles seem a bit freaky deaky so why not just go ahead and replace it all right the first time with good riding matched stuff (depending on your budget).
Due to the difference between front and rear, I am thinking about replacing the rear springs with 2.5" lift springs, keeping the front springs (or replacing with new stock height springs) and using the appropriate length shackles to maintain a level stance.
That being said and doing the math, it looks like I'll throw some +2.5" shackles on the rear and the stock length shackle up front. The rear shackles may not need to be +2.5", assuming my stock springs have a lot of sag.
Does this logic make sense?
