RedArc Tow Pro Brake Controller
Just bringing this back up, finished installing this morning. I had a great conversation with Redarc (they called me on their dime from AUS) and they assured me that the TPH-021 would work in my 2015. The better news is that they sell a complete kit that includes the Elite Pro controller, the TPH-021 harness AND the TPSI-002 dash insert as one kit, it is part #CIKTP-NA-002, same price as just buying just the controller, $250. I bought mine directly from Redarc, had it in about 4 days.
I had no empty slots in the left panel, so I opted to put it in the panel to the right of the steering wheel. I can easily see it while seated. Plenty of wire, in fact the hardest part was fighting with the wires to get them fully tucked and safely ziptied under the dash, wow it's crowded under there!
Did you ground the white wire that's part of TPH-021?
I forgot where I specifically grounded it, but you'll either see some existing ground bolts under the dash. Worst case us another bolt but confirm that you have bare metal contact and that the metal is attached to body not just plastic.
I used a bolt that connects the fuse block holder to the body. 10mm bolt that points toward the driver tire. In the area that I'm pointing to here.
All my tools are at my place in Austin, and the factory tool set saved my a** once again. The 10mm wrench in the toolbox has come in handy more times than I can count.
I’ve talked to the makers of the blank.
They said they have a 3D cad model for the LHD model but they decided not to make them due to likely low demand.
I’ve thought of maybe modifying the RHD…
I asked them if they’d make a limited run and if could buy them and distribute them to try to make my money back.
@82SC I know this was a comment made over 4 years ago, but I was curious if you tried to modify the RHD button panel? If not, I wonder if the makers of the blank would be willing to open the 3D CAD model to the world so we could try 3D printing it. I really need more buttons and I'd rather not go the SwitchPros route.
