Inaugural tow. Did great. The Redarc was making me a little nervous in that it calibrated for a long time...but then worked perfectly.
I can also confirm that the Redarc TPH-021 harness worked perfectly for my 2013 LX570. I did ground the white wire that came with the eyelet.
View attachment 2599523View attachment 2599524
The Redarc TPH-021 harness was plug-n-play in my 2018 LX570 as well as my 2011 GX460. The only thing you have to do is find a stud or bolt to install the ground terminal, otherwise it just plugs right into the oem connector.Bring this back up, planning to rent an RV trailer this summer at least a couple of times, and they require a controller. They can "rent" me a Bluetooth controller ($25 for each trip) that plugs into the trailer connector and you control it through a phone app, but I'm not crazy about that. I think I'd rather just do it right.
So my only question is, I know I had the original factory pigtail connector when I bought the truck 7 years ago, but I can't find it now. Should I bother to get one from Toyota, or is there a Redarc kit that plugs directly into the connector behind the dash? I'm not sure what the E-trailer site means when it asks about the "Factory Tow Package".
I have the "Toyota suitable Tow-Pro Brake Controller Harness (TPH-021)" in my 2018 and can attest it works with my Tow Pro Elite.Bring this back up, planning to rent an RV trailer this summer at least a couple of times, and they require a controller. They can "rent" me a Bluetooth controller ($25 for each trip) that plugs into the trailer connector and you control it through a phone app, but I'm not crazy about that. I think I'd rather just do it right.
The plate is VERY special. You're driving a LAND CRUISER!Thanks, I've been getting conflicting info, so this is helpful. On hold now with e-trailer.
How special is that little plate? Not trying to be cheap, but can't I just drill a hole in one of the blanks? All of my slots in the panel to the left of the steering wheel are full, so I'm gonna have to put the knob in the other panel to the right of the wheel.
I corresponded with REDARC. They're very helpful.So e-trailer was pretty much worthless. Their website says the TPH-021 only goes up to 2012, and they assured me that it WON'T FIT my 2015. Despite me telling me that others have installed it in later trucks.
And they had no idea what "Factory Tow Package" means, they said I needed to call me local dealer to check if my truck had it. Wouldn't listen when I told them that all Cruisers are equipped the same. Just drones on the phone reading their website to me.
Yes, e-trailer is useless but they are just following what redarc officially lists. The GX460 is not even on their fitment list at all for the TPH-021 but I took a gamble and it fit no problem and functions correctly. 2018 LX is not either but it works. I would imagine they didnt change the plug just for 2013-2017So e-trailer was pretty much worthless. Their website says the TPH-021 only goes up to 2012, and they assured me that it WON'T FIT my 2015. Despite me telling me that others have installed it in later trucks.
I drilled through a blank on mine. Used a combo of a dremel and a sharp drill bit to ream the hole cleanly. This was due to the plate not arriving in time. But hey, it saved me some coin and looks good!So e-trailer was pretty much worthless. Their website says the TPH-021 only goes up to 2012, and they assured me that it WON'T FIT my 2015. Despite me telling me that others have installed it in later trucks.
It would seem like a step drill would make a nice clean hole. I may give it a try when I do my install.I drilled through a blank on mine. Used a combo of a dremel and a sharp drill bit to ream the hole cleanly. This was due to the plate not arriving in time. But hey, it saved me some coin and looks good!
That’d work too! I used new drill bits to keep stepping up diameter until it cleared. Then dremel to shape up/knock off burs. It looks good to me!It would seem like a step drill would make a nice clean hole. I may give it a try when I do my install.
Thanks for the update and part number. I’d like to do this too.Just bringing this back up, finished installing this morning. I had a great conversation with Redarc (they called me on their dime from AUS) and they assured me that the TPH-021 would work in my 2015. The better news is that they sell a complete kit that includes the Elite Pro controller, the TPH-021 harness AND the TPSI-002 dash insert as one kit, it is part #CIKTP-NA-002, same price as just buying just the controller, $250. I bought mine directly from Redarc, had it in about 4 days.
I had no empty slots in the left panel, so I opted to put it in the panel to the right of the steering wheel. I can easily see it while seated. Plenty of wire, in fact the hardest part was fighting with the wires to get them fully tucked and safely ziptied under the dash, wow it's crowded under there!
I'll mention here that you need to have the test light connected to the trailer plug at the back BEFORE you can begin the test, or even put the unit in User mode. It will ignore you and stay in "Sleep" mode until you connect the test light. I made up a quick light with ~4' long leads and set the bulb on top of the tailgate so I could do the test by myself. I used a 12W bulb that I had in my spares bin, worked perfectly.I just performed the testing procedure that REDARC supplies to test the controller and it tested out as per the write-up.
REF:
Tow-Pro Elite Testing Procedure - https://www.redarcelectronics.com/au/resources/brake-controllers-faqs/how-to-test-tow-pro/
In case anyone wants to try this I used a Sylvania 1156 bulb and socket I had lying around for years.
The bulb is 12.8V/26.9W.
REF:
SYLVANIA 1156 Long Life Mini Bulb, 2 Pack - https://www.sylvania-automotive.com/sylvania-1156-long-life-mini-bulb-2-pack/1156LL.BP2.html
It shows the unit working in manual mode which obviously isn't a real dynamic test but I guess is better than no test at all.
This doesn’t surprise me.I had a great conversation with Redarc (they called me on their dime from AUS)
