Recommended shocks
Hello again.
My LC is a 97 CE. What shocks would you recommend for just daily driving? I believe it's been about 8 years since I've had any put on and it seems like my rig doesn't go over bumps as well as it used to. I just don;t want to feel like I'm being bottomed out every time I hit a small pot hole or uneven pavement. I believe I have Monroe shocks on it now.
Thanks in advance.
How are your springs? Probably original and sagging? Might want to change those too but yeah, just get OEM shocks unless you can get some like a Dobinson with springs for not much more.
The fox ifp are fairly soft without being mushy. But it sounds like your springs are tired.
Seeing as your truck is now 22 years old, and based on the fact that these trucks weigh alot in stock form, I'd think bout doing the springs, and shocks together. If you end up just replacing your shocks, don't forget about replacing the steering stabilizer too, It'll be well worn after 22 years of use.
Thanks everyone. I'll look into the springs as well.. Will the steering be affected by replacing the shocks and springs? I have no play in my current steering at all.
Nope, as long as you stick with a stock height spring it shouldn't effect steering at all. Also I will recommend the stock shocks as well. I am running them with Old Man Emu stock height springs and it's pretty good on the road. Offroad I think it's too harsh but just fine for DD duty.
tokico and stock height old man emu on mine..purrrfect for moderate loads on road and speeding thru winding dirt roads..
