I wrote up a quick how-to:
Hope that helps.
Georg @ Valley Hybrids, Cruiser Brothers & Long Range America
Hope that helps.
I rebuilding the cases for another member. I am not going to use these cases in my rig because I want to upgrade to the H55f and the split transfer case.Glad the info I provided helped.
FWIW, we sell the rebuild kits, Tcase & nose cone saver kits, dual-seal rear extension housings and much more ……
Happy to help.
Shop 209-475-8808
we build lots of those combos. Happy to help.I rebuilding the cases for another member. I am not going to use these cases in my rig because I want to upgrade to the H55f and the split transfer case.
What are the options? Would be interested in the OD Hi range and lower LO range.we build lots of those combos. Happy to help.
So far for gear boxes with over 100k miles and then set for 20 years there is very little wear on anything. The only wear I have found so far was on the idler gear one thrust washer was discolored, a little wear on the Idler shaft, and some minor pitting on the front drive shifter shaft.@POPO AGIE nice work! Question, can you take a close up of the steel spacer that's on the trans output shaft? I pulled my T case yesterday and noticed a little axial wear on that sleeve. I'm curious if yours is worn similar to mine.
