Rear wiper not working
So it was working fine, then after spraying the salt of the truck yesterday it stopped. The washer nozzle functions fine. advice?
I have an entire rear wiper assembly that I removed from my 1987 BJ70. 24volts. You can have it it you can pay shipping from zip 28379.
is it the wiper that stopped working or the nozzle doest spray?
for nozzle you have the tank and pump behind the rear right panel, carefull when you remove it so you dont creck the vent grille.
for wiper its in the rear right door.
on mine it started working very slowly, took the wiper gearbox -engine out ( 3 screws), then opened the gearbox lid and found the wiper axle jammed with rust.
bit of work and some grease and it runs fine now.
Idont have pics, worked at headtorch on it.
Nozzle works fine. I haven't had time to pull the door panel and inspect the motor. I will soon hopefully.
Side note, my interior grilles are jacked up. I'm having a friend work on a 3D printed one. I'm toying with having a pair printed in aluminum. I'll post more info in my build thread as it becomes more concrete.
