Rear sway bar bushings (but not the ones you're thinking of)
Calgary, AB
Anyone have a link or know a part number for the bushings for the ends of the rear sway bar where the sway bar link bolts to the sway bar? Mine are awfully loose now and clunk like crazy. Not talking about the sway bar mount bushings but way out on the ends of the sway bar where the hole goes through.
Links on Amazon or even RockAuto would be preferred as then I can likely order them easily for delivery up here to Canada. Otherwise a part number that I can search on would work.
Thanks.
there's a bit of variance in part numbers between different years, what year is yours?
I have a thread that has all bushing part numbers in it for 98-2003 and it includes some part numbers for newer models as well
edit:
Also honestly better off just buying new end links lol. If you're set on rockauto Moog has a good set there. I used mine for like three weeks then replaced them with extended links, would offer to ship if you were a bit more local
Have you tried Toyota in Ontario? You'll need a part number, but they're cheaper than anyone I've found in the lower 48.
Cruiser is a 2001 - I have new end links, this is on the actual sway bar where the end link bolts. The bushing inside the hole is very loose. I'll have it apart on Friday so I'll snap a photo then (have to pull one of my towing airbags to see where it is leaking).
Looking for the rubber bit in the end of the sway bar, it's very loose after about 1/2 million kilometres.
I thought you had said that you have new end links. That bushing comes with the end links
It's like $18
