rear spring flip question
I have searched but have not found exactly what I need to know.
I want to reverse my rear springs to help clear 33"s and increase my wheel base. Do I need to swap the front hanger and rear shackles like for a front reversal? The front hanger is outboarded from the frame. The rear is stock shackle set up.
Do they make a bracket if I need to swap the hangers. It seems like a simple mod but as usuall, I have questions.
Any info would be great.
I also took the second leaf on mine and redrilled the hole, keeping the military wrap on the hanger side like it should be.
It might be better for ride purposes to just redrill the perches and the u-bolt plate alittle further forward therefore pushing the axle toward the rear.I have be'en able to get almost 2" this way.I have found that keeping the shorter end of the spring in front of the axle allows more ease of movement /spring flex because of the shackle being on the long side.Just my opinion though.
I'll second that, except I had to burn the hole with a gas hacksaw...You must buy your drill bits from someplace other than China :rolleyes:
DON"T use drill bits. I used a masonary bit and was done in under a min. I tried to use a standard bit and it just wouldn't cut the spring.
I'll second(or third) the masonry bit comment. I drilled on a hardened screw for three days and four good steel bits with no luck. Used an old masonry bit I found and knocked it out in ten minutes. Thanks for the heads up.
A regular drill bit will work if your drill press can go slow (~200 rpm) and you use lots of cutting oil. Mine took about 5 mins each using my HF drill press, HF drill bit, and cutting oil. Low RPM's is the key.
Well hell, I guess everyone knows this trick but me :confused:
