Rear shock issue
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
As you can see from the picture I'm having a hard (very hard) time going over bumps. The rear shocks are still attached to the stock mounting postion after the SOA and now ith the top on I almost have no up travel left. My shocks are bottoming out before my stops are. They will have to be replaced. My question is.
Could I move the bottom shock mount to the Bottom Perch in this picture? Do you think it would give me enough room to have droop and rebound? I've got hyper shackles on it right now and the shocks are keeping it from full articulation.
Any ideas?
Do you think the perch is a good place to mount the bottom shock mount? Would a nice grade 8 bolt welded to the perch work for mount?
A picture of it extended.
Find a lift, unbolt the shocks and flex the suspension. Measure you're shock mounts (both above and below the axle) extended and compressed and find some that fit it.
You'll be fine using the lower mount as long as the shocks are long enough.
I would relocate your shock mount at the axle to below the spring. Perhaps weld a bolt to the old spring perch. I have my shocks mounted there. Also I moved my upper shock mounts inward a tad.
-Dustin
I did what nutley is talkin about. I cut the stud off the u bolt plate. I welded it to some 2" flat stock and welded that to old spring pirch that is now on the bottom of the axle at the back.
bustanutley said:
oh and ditch those retarded shackles
Hey:eek:
You will hurt my shackles feelings.
:flipoff2:
They are staying until I find a reason they need to be changed.
Good idea on reusing the old mount. Thanks guys.
