Rear Quarter Panel Wiring
For those that have added a fuse block to the passenger side rear quarter pa cel, how did u route the wiring from the battery to the rear?
There is a grommet in the firewall that will allow you to pull wire through it. Then you just put the wire under the carpet along the rocker panel and up into the back. Its pretty simple to route.
I ran thick 1 cable down the right side under the carpet in the channel.
I ran 2/0 cable the way @musthave did, down the passenger side. From the grommet at the firewall down under the carpet in the channel. I put a 150 amp breaker by the second battery to cut power to the rear fusepanel when I work back there.
Having done the same routing with my 2/0 (+) and (-) cables, and several other wires down the passenger side and in the channel, I would route the large cables a little differently now. I would pull up seat ( 4 bolts) and route the large cables under the passenger side footwell, as close to the heater as possible, under the rear passenger footwell and then up the rear panel.
You run out of room very quickly after several wires and a 2/0 cables. You end up squashing all the wires under there trying to snap the carpet back in place.
Just a thought.
@Dr Gil is right, once you start adding wires it gets tricky. I'm restoring my personal cruiser, and in the process all the seats will be out for sound deadening and new carpet. While I've got it out, I am going to run them through the grommet on the firewall, then down bottom of the hump along left side of passenger seat, and then back to the rear panel. I will install more cables and wires than I think I could possibly need so that I don't have to run more. To add to the complexity though, I have considered running them through a wire loom installed in the drivers side frame rail...
@musthave something to consider for the future. If you get a drawer system (I have a drawer system with 2nd row delete), you don't want to run the cables on top of the gas tank. You'll want to run them from the transmission hump in front of the gas tank and then to the rear panel. I was forced to do that because I currently have a drawer system, but wouldn't have thought of that if I didn't have a drawer system and my drawers would be sitting on top of the cables, or I would have had to re-route them, and then they would be too short.
As mentioned, there's a wiring chase along the passenger door sills. Just pop up the trim and you'll see it along the edge of the carpet. You can stuff a single 2/0 wire, or a 1/0 with a few smaller wires along side. As for getting it through the firewall, here are a few pics I shot during my install. You can run the wire through a dead nipple on the factory grommet. running wires / cables through the firewall.
Pictures definitely help
Did you guys run a positive and negative to the battery? I am installing a Blue Sea Fuse block on the rear quarter panel. It will run my front, side, and rear roof lights and the OBA compressor
Yes, as per the posts above, we both ran a 2/0 positive and negative cable down the passenger side. But in my post I am cautioning to run the large cables in the footwells, not down the sides, because it gets real crowded in that channel with just a few wires and those large cables.
The wiring gods will tell you that a dedicated (+) and (-) run from the battery to the rear QP is the ideal solution. That said, I run a negative lead from tmy second battery to the passenger frame rail (in the engine bay), and then from the same frame rail (in the rear) up to the QP. I've yet to have any issues, and I like keeping a strong ground throughout the vehicle engine, chassis, and frame.
Here's a few more pics of my setup if it helps. I run all my aux accessories from the rear QPM, including OBA. Wits' End Accessory Mounting Quarter Panel- need input
