All,
I rebuilt my motor, and realized through an oil leak I had not put in a rear main seal, What a PUTZ.
So couple of photos are attached. There seems to be 2 seals that need to be installed. The first is a rubber seal that is black, concave and fits nicely around the clutch nub (Pictures 1, 2 and 3)
The second is a seal that is white rubber coated with metal on the inside. It does not fit very easily over the crankshaft. Photo 4. Phot0 5 shows the flywheel with the rubber seal on the clutch nub, and the white seal on the engine side of the flywheel..which brings me to my dumb question:
Regards,
Boaf
- Which one is the rear main seal,
- do they both go on and
- how do I install the white rubber one? It is fairly snug on the crank shaft. The inside of the white seal has three (3) steel groves, assuming to keep oil in place.
Regards,
Boaf
