Rear Light Question
Near Junk
OK - 07/76 FJ40. Wiring loom looks to be spliced and modded numerous times. Trying to get rear lights to work and need some help. Have FSM and wiring schematic but wires going to the rear lights as part of the overall harness do not appear to be stock color-codes so need to back-track on some things first. I have stock (toyo) rear lights - not aftermarket. These lights have three bulbs with the middle bulb being double filament (brake one I assume).
1] How many wires should run to the lights from the wiring harness? I assume there should be 5 given the schematic but may be wrong. Again, I am asking how many wires from the wiring harness would go the rear light plug.
2] With lights on - which rear light(s) is/are powered? I assume the middle one only goes on which is covered by the red part of the plastic lense. Does the end bulb under the yellow part of the lense also light with the lights on?
3] For turn signal, I assume the bulb under the yellow part of the lense is the one that blinks right? The other ones don't I assume.
4] Does the rear light ground via its mount to the rear cross member or is there supposed to be a separate ground wire in the wiring harness?
5] Where is the switch or where does it connect to for the back-up lights (on transmission case, inside cab, etc..)?
Appreciate any help. I have weird situation where some lights go on and then others are very dim or blink on and off randomly. Also, lights get brighter when I rev the engine. Front headlights do not change - only rear lights change with engine rev so I assume my voltage reg is good.
AndrewT
The dim and bright problem suggests that you are lacking ground.
Come on - someone has to know this here. Only thing keeping my 40 off the road right now.
AndrewT
Yes 5 wires
a. backup lights
b. running/tail lights
c. right turn
d. left turn
e. stop
The "dim" filament of the center bulb only is on with the lights. The amber lights only work with the turn signals.
Correct
Light grounds to the frame BUT the lights all work better if you have a ground wire run to all of them. Front fender mounted lights are the most affected by bad ground.
Backup light switch is on the transmission. It connects to the wiring harness on the passenger side framerail.
As mentioned, this is usually a bad ground. It can also be caused by using a wrong bulb somewhere. I would start by running ground wires to the metal lamp shields inside the front turn signals. From my experience this is usually the problem. Contact Junk and see if you can check out how I wired his '77 FJ45 front signals for an example...
HTH,
Nick
Nick - thx for the very helpful info.
I do have a weird situation where the rear cross member does not seem to be grounded. Its been POR's and painted but I ground away down to bare steel and still could not get ground on that. Strange as I have battery grounded to the front frame and all other electricals work and have good ground. I will probably run some additional ground wires to ensure all frame components are well grounded.
AndrewT
