Rear Elec. Diff not Engaging & CDL 7 pin question
Hey guys! Looking for advice. After completing a Scan Gauge II install I decided to test all of the buttons to ensure proper operation and I uncovered something.
(see thread https://forum.ih8mud.com/80-series-tech/257562-scan-gauge-ii-install-96-fzj80.html )
Can I get your input on the following?
I have read the threads relating to this topic and Slee CDL/7 pin mod info.
https://forum.ih8mud.com/80-series-tech/128479-center-diff-lock-question.html
https://forum.ih8mud.com/80-series-tech/2151-low-without-center-diff-locked.html
http://www.sleeoffroad.com/technical/tz_cdl_pin7mod.htm
1st - My CDL button does not illum the orange diff lock or ABS annuciator when pushed while the transfer case is in High.
It does illuminate when after I shift it to Low and then press the CDL button.
Is this normal? Is it possible that the 7 pin mod was not done but the PO only installed the CDL switch?
2nd - the stock elec rear differential will not engage or rather the light will not stop blinking after the dash switch is selected. The front indicator glows solid red after several seconds. I tried selecting and de-selecting the diff switch several times hoping to exercise the locker and associated hardware. This did not work.
*Note - This is only the 2nd time that I have turned on the elec diffs. The 1st was last month when I test drove the vehicle the day that I bought it. At that time the diff annunciator glowed red after several seconds. Both of them. At the time though, I was not aware of the 7 pin mod & seem to recall the same thing as stated above happening.
The CDL allows you to have full manual control of the center diff in 4LO. The pin 7 mod allows you to have full control of it in 4HI also. Did you do the pin 7 mod? If so, it sounds like it didn't work. You sure you did the correct wire?
The center must be locked before the axles will lock. I assume this is happening because you said the front lock light is solid. If the back is just blinking it could be stuck. Blinking means it was told to engage but didn't or can't. Try turning to dial to RR and driving in circles. Can you hear the actuator working?
Does it get really hard to steer when the front is locked (i.e. have you confirmed the front is actually locked)?
If so, just concentrate on the rear because you know the front works.
I bought it as is. I did not do anything to the CDL or 7 pin mod. A previous owner (PO) must have put the CDL switch in.
I did shift the transfer case to L before rotating the selector. I felt a change (more grabby) after front engaged (solid front diff light) and drove fwd and back (in straight line) on muddy road while rear light was still blinking. I did not turn the steering wheel while locked because I read somewhere (not sure where) that you shouldn't turn the front wheels while front diff is engaged.
I will do the circle trick for the rear and look into the transmission relay to see if the 7 pin was actually done tomorrow.
Thanks
BTW- I was in SD for 6 years up untill a few years ago. PB & Coronado. Loved it! Hopefully going back soon!
You can turn the steering wheel. In fact, it makes it darn hard to go where you need to go or to follow your spotter's directions if you don't turn the steering wheel. :D
You probably read that you shouldn't turn the front wheels when locked on a high-traction surface. This is good advice, but you shouldn't be engaging the rear or the front unless you are on a low-traction surface.
Your rear probably didn't engage because you need ~15* differential for the cogs to align. Look at a picture of the rear locking mechanism and you will see what I mean. The easiest way to get them to lock is to turn in figure-8's or circles on a low-traction surface. After you get in the habit of exercising the diff locks every week or two, you will find they engage virtually instantly (within 3 seconds). You should be driving slowly as you test them.
-B-
Thanks for the info. I will test and let you know how it went!
OK, keep us posted. Oh, and like B said, turn the wheel when engaging the lockers. At least, it is easier if you don't drive in a straight line. I usually just weave back and forth slightly and they pop right in.
If you ever make it back to SD, look me up. We'll have to hit a trail or something.
Caution when inspecting for the pin seven mod. the screws on the silver box you must remove to get to the transmission relay strip easily. AND also there happens to be a blue wire w/ black tracer as well as the black wire w/ blue tracer..........................chose carefully.
I checked the diffs again. Thanks Beowulf & sdnative for the advice. The rear reluctantly locked after turning the wheels and slowing moving. I cycled the switch several times allowing enough time for the system to do its thing. I heard the realys click then the lockers click as it locked and then unlocked. The front took about three seconds to lock but the rear indicator immediately went solid after the second & third trys. Unlocking, it took several seconds along with driving forward or back for the lights to go out.
The 7 pin mod apparently was done because the orange diff and ABS annunciators illuminated in L & H when the CDL button was pushed. I can't explain why it didn't work last night other than the freezing temps. It was a little warmer today though. ?????
