rear disc conversion
JDNs78FJ40
Draper Utah
So at the last minute I decided to convert the drums to disc on my 78. I got all the parts coming from @Poser and hope to install this weekend. I just want to purchase/source the fully loaded calipers from a local auto store. Has anyone recently purchase these from Autozone or Napa and have the part numbers handy or do I need to purchase them online.
I bought my rear brake conversion through JT outfitters and it came with everything I needed, perhaps slightly more clear instructions. That said – everything fit and it ultimately was pretty simple to put together and it’s made a very nice difference in how the truck brakes.
Edit - to be clear I’m NOT suggesting that over @Poser set up, just offering that it’s worth doing the conversion.
Jim info:
Use a pair of 88-90sumthin V6 4runner front calipers to get increased clamping power on front axle.
Use the common GM swap on rear axle with cheap ceramic pads for less bite.
F-R brake bias is just about perfect with that setup. On a customer truck, I still install an adjustable prop valve in the rear, but it is dialed out all the way as it is not needed. On my FJ45 there is no prop valve and no premature rear lockup.
Where do you buy from, does @Poser have a storefront or website?
I’d strongly suggest putting in a rear brake proportioner - strongly suggest.
Wilwood make a nice rotary dial one that works great.
