Rear Ding Ding Ding Ding
Rear u-joint guaranteed. I will bet you its the one up closest to the transfer case. You can test this by just greasing the joints and seeing if the sound goes away / lessens. I used to have the same issue.
Greased and took a better look at the u-joints. The one closest to the rear diff, has its race broken. I think its called that. That round piece of metal that holds it in? It bent out and clicks when goes a certain way (reverse), and can click when going forward. I'm planning on replacing both joints real soon.
Hey this sounds like my problem. Originally I thought it was my exhaust too, but now I'm getting a vibration on acceleration. The wierd thing is I greased all my joints only 1,000 miles ago at my oil change. I figured I would reanimate an old thread rather than start a new one. How did this turn out?
Well as it turns out the only way to know for sure is to buy four of these and using an assistant to "drive", slide under the rig and listen.
Not sure if he will respond but I highly recommend pulling the shaft if you are still getting the ding after greasing. While you have it out dive in front wheel drive with the center locked and listen for your sound.
The u joints aren't too bad to replace you will just have to watch out for falling needle bearings when you put the new ones out. They like to fall into the bottom of the caps. I think OEM wholesale for around 58 or so. After market ones can be had for around 38, if you want to save a little in the short run.
Matthew
I wouldn't drive the truck at all with a busted u-joint. If it lets go at speed, you're going to trash your cruiser. Beno posted a thread a while back where a friend's u-joint gave way, the drive shaft let go, and it popped a big huge hole in the transfercase or transmission housing. You're talking about a multi-thousand dollar repair.
Yeah, thats what I'm worried about. I have some tools with me, how bad would it be to pop the rear shaft off before driving home? Is it too complicated?
It's not complicated at all. With an FJ80, you've got the standard center differential lock (CDL) button, right? You'll want to engage that before you remove the drive shaft. If you don't, the vehicle may roll, even on "flat" ground, and you won't be able to drive it, because you will have your center differential open with nothing to turn, just like having a car wheel up in the air.
However, you should know that driving with only the front driveshaft in may put more stress on those joints and, if they're in the same state of disrepair as your rear joints, cause some problems. If I were you, I'd replace all four asap.
Check the crush sleeve on the rear diff. Mine came loose and gives off a nice hollow jingiling sound. I really love it.
I pulled the rear shaft off, and on the diff U-joint I found what I can only describe as a "dead spot," just a sort of a catch or something. When its out and in my hands, its not much but under acceleration I imagine that little "catch" is the source of my shudder during acceleration. Anyone have similar experience as far as it not feeling like a huge obstruction once its out?
Yup its bad. Just replace it. That may not be the whole problem though. You should check the flanges on the transfer case and the differential for play.
What you found is exactly what I was trying to describe in another thread. I call this a "wear notch" it is very common and will definately cause vibration at speed, especially if you have just lifted the vehicle.
You will need a press to properly R/R the uni joints. Don't bother with aftermarket parts for this application. Buy new OEM uni rebuild kits from Toyota. They're about $50 each and will last another 150K miles.
Yeah, I'm glad I caught it before it became a problem. A week or two ago, it was just the knocking sound on decel that I thought was a broken exhaust mount allowing the pipe to hit by the T-case. Then yesterday, it went all weird with the shudder on acceleration. It was worse after school than it had been on the way that morning so it was going downhill quick. I'm just glad I pulled it off before it cut loose and tore everything up like my buddy did on his old F-100. :(. Anyway, I'll be making extensive use of the FAQ for getting them put in. Thanks all. :).
