Rear differential up and down movement
What year is your FJ60?
^^^ that's the right answer. When you remove the flange you're removing all Pinion preload, and that impacts backlash because the Pinion moves inwards.
Factory crush spacer, you gotta be careful reinstalling the companion flange so you don't mess up preload. Same number of turns on the nut kind of thing.
Good luck.
