Rear Diff Removal Question
supercarrera
Club Esprit de Four
Santa Clara, CA
Website
www.instagram.com
So I'll be removing my differentials for re-gearing and I'm reading through the FSM. The removal procedure for the rear involves "installing the spacer and pinion shaft to the differential." I basically don't know much about differentials. What does this mean? :hmm: Can I just skip this step?
assuming full float, If your removing the entire diff, you don't need to do this. Just lock the axle(if you have locking rear diff), pull the drive shaft and the axle shafts, unbolt and pull. (note, you may want to drain fluid first, to keep floor clean.)
It's heavy! I did the R&R by myself when I installed my Aussie, but I'm a badass. :rofl:
If it was a semi float, like pictured above, wouldn't have to pull the diff to install the Aussie.
Anyone know how much it weighs? I was planning on pulling it myself. I'm pretty badass too but now I'm a little worried. I have a full floater by the way.
Yeah, 90lbs seems about right. I have one in the garage in a bucket and it is not easy to move around. I'm not Magnús Ver Magnússon, but I was able to remove the differentials myself with some careful planning.
It helps to use a floor jack to support the differential until you get all the nuts off. Then you fight the RTV a little and whamo, its ready to remove.
Closer to 100 lbs. It feels like 150 to me:doh:
It's heavy and awkward as hell, but I've pulled an installed a bunch of them. I am not a badass, and still get it done. It really helps to have a floor jack or transmission jack. It's easy on a full float axle. If you're lifted, you don't even need to jack it up. Just be careful and wear heavy leather gloves in case it lands on your hand. Trust me on this, I have scars to prove it.
