Hi all, For the last 2 years I have had an oil leak out of the front diff oil seal. So I pulled it apart and changed it out. It started leaking again within a month..So after reading some other posts about this issue I tore it apart again and had a sleeve put on the coupler and then put it all back together again (with the proper torque) and it started leaking again in a week or so.
Does anyone have any input on what to try next?
Thanks.
Gear oil can leak out the splines, even if the oil seal is functioning perfectly. It looks like the seal is leaking, but the oil is coming from the inside of the flange.
Normally. When a shaft seal leaks, the problem is not the seal, the problem is the radial movement of the shaft inside the seal.
Radial movement is present when the pinion bearings are worn or bearing preload is not sufficient.
Replacing the factory crush sleeve is a good idea but when a solid spacer is used it has to be shimmed in order to end up with the proper bearing preload at the specified pinion nut torque value.
In other words, you really need to pull the third member so gears and bearings can be inspected and possibly replaced and in the process, set up the pinion with a properly shimmed solid spacer from the start.
