Rear diff oil leak
Boston
Hi, I have a 93 FZJ 80 that has a slow oil leak coming from the rear diff area. I think it’s a bad pinion seal but was wondering what other people thought? Also if you know the part number for it that would be much appreciated.
Thank you
Is the breather clogged?
[/QUO
To be honest I'm not sure. I haven't driven it since I noticed the leak and haven't had the chance to really take a look it. Also not sure really how to check if it's clogged.
pull the breather off and put a small screwdriver in it to see if its plugged with crap on the axle, then blow air through the tube going up to the frame and put back together. Probably there is gunk in it.
Looked exactly the the leak on mine and the seal was shot. Make sure to put in a toyota factory seal as its 100% better than any other "car parts store" seal, its a fairly simple job to replace
