Rear defrost switch
Panamá
Website
www.4x4panama.com
In a search I can locate any pin diagram for the switch .. but I know other as Mr. Dan used it to activate other stuff ..
Well .. that's why I'm looking for if anyone have a diagram ..would be uber nice ..
thanks !
David
I have the 80 defog switches for both my fog and aux. lights.
6 pins on the plug. 1 in unused, 1 is back light, 1 is dimmer rheostat, 1 is the switch ground, 1 is the switch positive from relay and the last is the indicator light orange bulb.
Slot 1, Green (12v +, for rheostat)
Slot 2, Yellow or black w/orange stripe = illumination (power?)
slot 3, White w/ black stripe or blue w/ white stripe (Ground)
Slot 4, white w/ green stripe, (12v –, for rheostat)
Slot 5, not used
Slot 6, Blue w/orange or black w/ yellow stripe = Relay (power)
Thanks guys .. I just realized I got the switch but not the plug and that will make the conections a bit more dificult .. I would need to figure something to make the cables fit in the tiny space ..
one more question guys .. what you mean with
rheostat
How much amps can handle those switches .. ? at least 15 amps ?
Do you thing it's posible just to intercept signal ( 12V ) from the batt in the switch and when the switch it's on allow the 12V continue to the destination .. ? I already have a rellay that activate or de activate the device ..
Rheostat is the type of switch that the rotary dimmer switch is.
Use a relay. Don't run battery power through it and go to the junkyard and get the plug for the switch. The plug is common for alot of toyota models. You may need to change the wire around in the plug though.
I forgot to get that diagram but will grab it tomorrow for you.
Well .. working on it and triying to figure how to make the idiot ( me ) light come on when the switch it's on I make a short .. and believe smoke on of the lines of the switch ..
It I put 12V to the 2 port .. and switch it on, I got 12V in the 3rd and 6 .. well now just in the 6 port .. and still the light didn't came on ! ( x2 idiot me .. )
I was playing with the switch this week, this is what I have figured for how it works.
Thanks for posting the diagram trk204.
Tapage - you probably burnt the orange indicator bulb out
Thanks for postink TRK I wish Ihad it before but will double check the bulbs and lights now with the diagram to the if I can make it work
