Rear Caliper swap?
cruisermatt
Un-manufacturable
Supporting Vendor
Winter Park, Florida
Website
www.cruisermatts.com
Has anyone found a brake caliper that bolts onto the rear housing (FZJ80) that would be considered an upgrade? More pistons maybe?
One of the best and cheapest upgrades I have done.
You must wear your seatbelt as several people I know directly have hit the windshield during a hard stop, after this Mod.
Thanks for the useful input!
On a Serious Note:
You can lock up the Caliper to rotor, so that the tires skid.
How is better calipers going to help?
Do you want a quicker stop?
I would chk condition of rubber hoses, replace brake fluid, Ensure caliper pistons are not stuck, and grease pins, Install EBC Greenstuff Pads and Slotted and Drilled Rotors.
If you have already covered these items and are still not happy then I would look at getting tires with the most surface area and softest compound (will last about 40K miles).
I know how to make a good brake system. That wasn't my question.
My question was: are there any other brake calipers that bolt in place of the OEM rear calipers?
Thanks
@Hornd that is brilliant!
@cruisermatt I have dug through in the past to see if there is anything better and have not found anything on the caliper side. You might have luck increasing diameter of the booster or reducing the diameter of the master cylinder to just get more pressure. But more pressure is more heat in the brakes and they aren't designed for more heat. A while back I was looking for a way to make 5-bolt hubs and Tundra "Big Brakes," but that was cost prohibitive for all but @scottryana
My personal opinion is that if you really believe you need better braking performance, then you're likely exceeding vehicle limits in some way, or have an unreasonable expectation for the vehicle. I use the word "unreasonable" lightly; I really just mean its a big fat pig and more would be gained by changing your driving style instead of trying to get better performance out of the 30 year old design. I came to terms with it just being slow and drive it accordingly(when I was driving it).
Thanks for the input guys. Still not what I was asking for but oh well.
Why you want Track Brakes on a Tractor Motor?
Motor has nothing to do with it.
I'm eliminating my LSPV and if I still feel like I could use more rear braking performance (I can't feel ANY right now) then I will be looking to upgrade those too. My fronts are as good as a front 60 brake system can be.
I have a feeling FJ40 front calipers might bolt up... Picking up another 80 axle in December so I'll be able to play around with this without taking my truck off the road.
Why you want to eliminate the PV when it keeps the backs from locking up (entire purpose of ABS it to keep wheel from locking up)?
Most trucks have a Drum Rear brake (2016 Tacoma comes to mind) and you have discs which is even more powerful, yet think you need more??
The shear stress on a brake is not anything I would want to mess with, but carry-on and stay safe. By Physics the force applied by the brake is equal to the force applied to the bolts holding it and the vehicle momentum is conserved.
Brakes are the single most important safety device on any vehicle, and God forbid there is an accident, any lawyer will avoid you like an Ebola Outbreak.
If you put in a manual front/rear proportioning valve you could then give the rear brakes more force. I'd think you would have to have some sort of proportion valve if you take out the factory one.
I put on new OEM calipers and LSPV and soft lines, but had to give the LSPV additional height adjustment before the rear end felt like it was braking better and not nose diving all the time....maybe you simply need more rear proportioning.
@Hornd You can repeat yourself till you are blue in the face but you're just not getting the point of this thread.
I'm out of here, see ya' later 80 section.
I don't have an 80, the 62 LSPV is completely different design and doesn't effect the front at all.
