Does anyone know how to split this bumper? I would like to separate the tire carrier/ladder arm from the bumper for powder coating and ease of transportation. I believe this is a Man-a-fee bumper, on my 75 FJ55 Thanks
Negative on the allen bolt on the cap. Stripped away all the coating in the area and nothing. I may have to try swinging the arm out and using a hi lift jack under it near the spindle to help it off… to be continued.I'd imagine that there is an allen bolt on that cap somewhere, that you would loosen, to remove the cap and slide the rest up off the spindle
This. Likely the cap is an interference fit and has to be gently pried off. Underneath is likely a castle nut and a cotter pin.Nut on the undersid?
The last 1’ of the bumper on each side is boxed in. If I am unable to bump it off with a jack, it may be an option to cut a window under the spindle.Nut on the undersid?
Great advice! Thank youThat is a bronze bushing pressed into the swing arm.The bronze bushing is swiveling on a spindle which is welded to the bumper which is bolted to the truck.Tap the swing arm back down on the spindle.Clean up the exposed spindle with some emory cloth.Spray some lubricant between the spindle and the bushing in the swing arm.Keep swinging the arm back and forth to work the lube into the bushing.Swing it back and forth as you continue to lift up.It will come off with some effort.
There should have been a lock collar on the end of the spindle above the swing arm bushing.
That totally looks like it would fit. I’ll look into sourcing something similar. I’m also thinking of placing some sort of nylon washer/bushing on the bottom of the arm so when it swings it’s not metal on metal, (or coating on coating).
