- Thread starter
- #141
Weights and measurments were very helpful. Looks like about $50 shipping for me, not bad.
I'm still very interested in the bumper. A few more questions before I can commit.
1. Concerning the bumper spacing with my body lift: Does the Top plate (the ones with holes for spindles) weld to the top edge of the bumper bracket I posted in the picture in this post: IH8MUD™ Forums - View Single Post - Rear Bumper Build
"Any way I could move the brackets to the inside of the frame, and put a 1.5"-2" block in to move the whole assembly up? moving the brackets inside change the scale of the angles of the bumper?"
2. What was your source for the spindles?
3. Do you have a way to hold the swing arms out if the truck isn't level?
4. Have you worked up the pricing for the swing arms? If I do this bumper, I'd like to buy 2 swing arms with the bumper.
Sorry it is taking so long to get back. Been crazy at home and work.
1. The top plate does weld to the top edge of the number bracket. I would just get another piece of steel about 1.5" wide and as long as the bumper and weld it to the back side of the top plate. This would fill in that gap. There is no way to raise the bumper up. It would change quite a bit.
2. I bought my spindles locally.
3. I don't have a way, but have begun thinking about it. Best way I can think is drill a few holes in the top plate and get a spring loaded pin to drop in the hole. The spring pin would be attached to the hub on the tire carrier.
4. I don't have pricing on the swing outs. Bearings and spindle alone are over 65 bucks. I don't really want to give you a quote until I hear back from the CNC machine shop making the hubs for the tire carrier. I am not sure how much the steel is going to run me either. Hopefully I can get this info in a day or so.
Any other questions? Hopefully this helped you.
