Remove the diff lock indicatior switch and actuator, put the shiftfork in the locked position. Cycle the actuator to be in the locked position and put it back together.
Skillet said:Will it ever end?
Rookie2 said:Don't know why in the heck you've pulled the axle shaft to change brakes. Most of this maintenance stuff is easily doable, but you've got to have your act together or you will most likely run into problems and get frustrated. My experience with wrenching is that it goes much smoother if you have the FSM, run a background check on the proceedure FIRST by doing a search of the archieves and see what pops up, have the right tools, and allocate plenty of time for the job. I suspect you are short on one or more of the items above, and hence the frustration.
Good Luck.
Rookie2
TLCgrappler said:Am I understanding it correctly that if he was able to drive it, it means that they did it correctly and didn't screw up the lockers? I hate not being there to make a judgement of my own.
Ken, this is a very good thread but the pictures are missing. Is there anyway that you can add those pictures back? Thanks.
This is a good info for those who wants to retrofit or do their PM on rear axle. It is an old thread but pack with good info.
Ditto. It would be great to get the pics back. I'm assuming that after awhile they are removed to save some bandwidth but ... Thanks.![]()
The issue with the rear factory locker is if you pull the axles out while it's unlocked, it's possible that the locking slide collar can fall out of position. This shouldn't be an issue if the 3rd member is already out.Reviving this ancient thread. I had my front/rear e-locked diffs pulled out and sent for re-gearing. Did not lock the diffs when they were pulled out. Now I have my rebuilt diffs back and ready to go back in. Am I in trouble now? Or, what sacrifices need to be made to T-gods to get my rig back together?![]()
