Evening,
I pulled the rear 3rd on my 94 with factory lockers, because the diff was howling and grinding pretty badly. PO did a gear swap and I suspect did not do it properly (already had to redo the front). Anyway, this was my first time pulling the rear axles out. Divers side had some soupy gear oil and grease mix. The inside of the hub looked pretty tore up - like the seal was spinning in its seat. Does this look normal? Both sides are the same.
Also, my rear locker has never worked. I figured it just needed cleaned and rebuilt. It would appear it contained a significant amount of water and then froze. The whole housing is cracked out. Not to mention the incredible corrosion. Looks like its time for a whole new actuator. Bummer.
