Rear axle help!
perth aus
Hi all
Looking for some guidance. I have a 1193 1fz 80 and I just did a rear wheel bearing Install
Right now there is no brake or rotor on the hub
Put everything in and seemed all good! But is it normal for the hub to spin when there is no
Axle, but I put the axle in and it’s seated but it doesn’t want to spin.
I took it apart and put everything back in, made sure that everything is seated. Same issue.
Any ideas?
But is it normal for the hub to spin when there is no Axle,
The rotating hub should rotate on the spindle without the axle installed. The axle is what drives the rotating hub.
If the axle is installed, the rotating hub is now secured to the axle.
Please download the Toyota factory service manual (FSM) from the resources section. All your questions will be answered.
