Realtime part number help
Anyone know the correct part number for the flexible brake line that runs from the left of center top of the front axle housing straight up to the hard line connection?
90947-02A18 is the hose part number
90468-08034 is the spring clip
Nobody wants to know what he plans to use it on?:)
oops, was in a rush, 96 FZJ80 US spec. The Toyota parts diagram seemed to indicate left and right options for that line which was confusing. Thanks for the replies.
The tech story was mystery loss of brake fluid, then truck stored for three months, then first day out of storage brake light on full bright with a full reservoir and good braking function. Later that day a sudden loss of pedal followed by a puddle of brake fluid under the front axle. So must have had a pinhole leak before the original line ruptured after 22 years of service.
There is no “seeming” to it. They are side specific.
Left side front frame to axle housing flexible brake line on order. Thanks for the help.
You're not going to replace all three?
A couple years ago I bought a (?complete) set of new flexible lines from someone in the classified section, so should have most of the lines already, have to dig them out of storage in a different location than where the vehicle is currently. Planning to replace the one ruptured line now to get the vehicle back on the road. Thank you
for what its worth, the RH side is 90947-02817.
LH Side is longer and has a male end and a female end.
RH side has two female ends.
The center one is the one I was referring to. If your flexible line is damaged, OK. If it needs to be replaced because it's old and failed, you should consider replacing all three, the left, right and center (90947-02934).
Thanks for the info; the caliper flexible lines were replaced eight years ago (time flies!) when I last did the front axle service and look good. The axle to frame lines are the originals. Thanks to everyone for the help.
