really anoying sound....
north vancouver
hi guys..
I am ready to drive my cruiser off a cliff..... I have this really frustrating noise...
when driving around 80k, 2-3 k rpms. if i take my foot off the throttle I get this lound gear like sound, with the application of a tiny bit of throttle it goes away.
this sound is 100% connected to the throttle, or when the engine is under load. take my foot off the throttle, the noise appears.
If I put the engine in Netrual the noise goes away, I cant get it to make the noise unless its in drive.
I have checked all the exhaust, both berfs have been overhauled, looked for every loose thing i can think off.
I am wondering now about transmission or front diff, ...
anyone have any ideas.
me......:bang:
you guys....:idea:
thanks.
scott.
Does it go away if you're in neutral and apply throttle?
yup. it does.
does not really do it at lower speeds, just on the highway at around 80km
with throttle, no noise, take my foot off the throttle it appears instantly.
it seems to be rel;ated to engine load.
yup. it does.
If you're in neutral and applying throttle, and it goes away, then it's not related to your drive train at all. It has to be something in, on, or directly connected to the engine itself.
Unfortunately, I don't have any ideas for you other than the obvious (bearings/pulleys, belts, etc). Browsing the troubleshooting docs in the FSM doesn't turn up any suspects either.
there has to be something that has to do with the engine being underload, or the drive train being underload. when its not being driven by the engine, it makes the noise.
Sounds like a worn slip yolk/uni to me. If you can make it come and go by finding the "sweet spot" between acceleration and deceleration, if it only happens at highway speeds, if it sounds more like a buzz, then it is a driveshaft with excessive play in one or more of the joints.
Typically a worn slip yolk will start to "flop" around when it is not being driven or under load. Toyota OEM joints are usually very tight but any joint needs to be properly lubricated to work properly.
x2, take a look at your driveshafts. The problem might exist there. I have the notorious "decel growl" Mine started doing this after lifting it. At this point I have a 4 inch lift and I'm running a CV in the front, that hasn't fixed my problem. I know for me it's the front drive shaft becuase I ran my truck without it and it was fine. My rear shaft is also doing the same but not as much as the front.
Take you front drive shaft off and see what it does.
-Juan
I have taken my front drive shaft out, the u joints have been replaced, there did not seem to be anyhting wrong with the old ones, add more oil to the front diff, it was down a bit,
the noise is still there only not nearly as loud. the front drive shaft is still out. oil checked in tranny, I did notice a fair bit of back lash in the front diff,
thoughts?
