Hello all,
I typically handle the work on my own rig, but I'm pressed for time lately so I've reached out to a Toyota specialist I trust to do the following labor:
LABOR ONLY PRICING
- Axle Bearing and Seal (Rear Driver and Passenger). - $925
- Timing Belt Project with Coolant (Toyota Super Long Life we will supply) - $1065 (we will drain the radiator, hoses, and engine block)
- Crankshaft Seal - $50
- Cam-Shaft Seals - $150
- Passenger cv-axle assembly and axle seal - $375
I am supplying all the parts (all OEM Toyota Parts). I think the pricing seems to be fair, but it's been a LONG time since I've paid a shop to do work so I wanted to double check with you guys.
The only critical issue right now is the rear axle as the passenger side is leaking and has fouled my ABS sensor. I need to get that addressed ASAP, the Timing belt is close to due, but I could possibly push that off for a bit.
Thanks in advance everyone!
LABOR ONLY PRICING
