Real time help - front driveshaft issue...
Prescott Valley, AZ
The "rumble strip" vibrations appeared on my truck yesterday.
After some checking it the forwardmost U-joint on the front DS that was sloppy.
I pulled the 4 bolts off the front of the DS and removed the forward half of the slip yoke, and its definately a shot U joint.
Now, the spindle or whatever the name is that the DS bolts to, should it have any play when you rotate it?
The vehicle is in park and the wheels aren't rolling. Is it normal for me to be able to spin that piece about an inch back and forth before it stops?
ahh, good.
I was all excited after finding out it was just a worn Ujoint, and then I moved that piece and started getting worried.
Ok, so I got a new U joint from Napa which was also greaseable, just on one of the endcaps instead of the center like the OEM one removed.
That definately got rid of my vibrations.....except for a few MPH.
From about 53-56mph, I get a lighter vibration. Any speed below or above that, no vibes at all.
The rear UJ in the front DS seemed fine, no play when I dropped the shaft down on the rear one.
Could it be something else?
I'm figuring an unbalanced tire would shake at all speeds....any ideas?
Did you only replace one u-joint? That's a no-no. Also, did the slip yoke get put back together in exactly the same alignment?
-Spike
Yes, just replaced the one directly behind the front diff. The yoke I marked and put back the same way with the marks lined up.
I had no noticeable play in the T case side on the front DS...do they have to be replaced in pairs for any specific reason?
I mean...is it just common practice, or will a new one somehow destroy the seemingly fine old one?
You probably got rid of a baseline vibration you weren't all that aware of, and now that it's smooth you can feel the light vibes. For that mph range, I'd drive it and see if it works itself out.
Although you might infer at this point that it's time to change out all of the u-joints. Kind of like lightbulbs. Once they start to go they may all be close, and you'll save yourself some time and labor by just doing the whole thing at once.
If you replaced the u-joint yourself, it is also possible that you knocked the drive shaft a little out of balance. That could contribute to the mild vibration.
Also, make sure everything is phased properly. You would not believe the vibrations you can get from having improperly phased drive shafts.
Replacing only one U-joint is like taking a shower and then putting your dirty clothes back on.
The OEM u-joint greases through the center in order to distribute the lubrication equally and to maintain a neutral balance in the joint.
Cody, I wouldn't put much time or $$ into it, get your caster correction installed, I will bet you need will a CV shaft anyway.
First, the 'seemingly fine old one'- I've replaced u-joints that had no noticeable problem upon examination, but were junk nonetheless.
Second, try to imagine the vibration of a bad u-joint. Imagine how fast the driveshaft is spinning. Imagine how much of a beating the 'good' u-joint takes while the 'bad' one bounces around. Imagine putting an old part through a stress test like that.
Third was already covered by someone else- it's every bit as old as the 'bad' one, what makes you think it's gonna last another week? You've already done most of the work to pull it out, how hard would it have been to replace them both? If you broke a belt on the engine, would you ignore the rest of the belts? Replace one worn-out tire? Hoses? Spark plugs? U-joints?
-Spike
That's probably true, but you won't know for sure unless you have a good driveshaft to test it with.
Just to depress you even more, I personally would have done both shafts, as it is full time 4wd.
-Spike
-Spike
Easy;
#1, About 5" of lift and proper caster correction = needs CV shaft for smooth running.
#2, Put the CC on and toss an angle gauge on the pinion, it points at the transfer = needs CV shaft for smooth running.
#3, It has a light vibration between 53-56mph, put the CC on, if the vibration gets worse and/or over a wider mph range = needs CV shaft for smooth running. If it's the same or less, get the shaft properly rebuilt and balanced, if the vibration is still there = needs CV shaft for smooth running.
I wouldn't waste anymore effort on that shaft, put the CC on and see what you have. Chances are good, that shaft is going to live in the spare parts pile, soon!:D
Not always true as I found out a few weeks ago. Someone installed my plates and measured the pinion angle at the front joint to be between 0*-.5*. He then stated the truck drove perfectly with the stock shaft.
Don't ask me to explain it but there is another guy who is going to try it out as well. Any idea why this happened?
That would be me Rick. Yep, driveshaft angle at the pinion sitting between 0* - 0.5* and I don't have any vibrations. U-joints tight and well lubed. I have had it on the freeway up around 75 mph with no issues. I was actually hoping for a noticeable vibration so I could get my DC or CV driveshaft ordered and on the way. So far so good, if I grenade it soon you will all surely find out.
