Real time help 95 died while driving.
Ok I switched the efi relay with the windows one nothing. Closest Toyota dealer ship that has the fusable link is 3 hour drive. So before I drive all that way I want to make sure this is the problem. I ran a wire to bypass the white plastic fusable link just to test with key in on position. I hear a click when it's connected but still no reading on the scan gauge, no check engine light, no start?????
I'm running out of time here.
Like I wrote:
"Main 2.0L fusible link provides power to the EFI 15A fuse."
That's the blue wire in my picture above.
I would bypass/check ALL three fusible links just to be safe. Of course you need to be careful with each bypass since even though it's likely the fusible link blew/deteriorated from old age, that possibly it blew to protect some short.
I assume you've checked the EFI fuse etc. There's a LOT of fuses in an 80.
cheers,
george.
I found a Napa close got a ride going to build my own fusable link assuming all three should be 15a. I guess close carries close here is 40 min drive.
Nope - they will be a LOT more than 15A... Consider, alternator charge goes through the blue one... If you put 15A FL wire they will blow real fast...
cheers,
george.
So what size?
So what size?
Fusible links are there to protect the wiring. AFAIK toyota (and most manufacturers) don't specify the ratings so you're left to guess or buy OEM.
As a total WAG I'd suggest something in the 60A or more region at least to get you going. I personally would just use a 16g wire to bridge across one FL at a time and check/ensure that the wire is not getting too hot or wanting to melt (in case the original FL failed protecting a wiring short).
After all we're only at the stage of locating why your CEL is not lighting up and thus your ECU is not running...
I presume you have checked your fuses, especially EFI etc??
cheers,
george.
I can't figure it out I did a direct line to test get a click in the relay that's it. I'm done just called for an expensive ass tow truck to take me to I'm sure a more expensive backwoods mechanic.
Where are you at? Someone might be close to help ya.
Where in Texas? I'm assuming north Texas (TTRA?)? I'm on shift today but can help first thing in the morning if you're not too far.
Btw, I seriously doubt the computer is fried. Jump all 3 fusible links at once, not one at a time. If you're not getting the CEL then it's the EFI fuse or a fusible link.
I was in Limestone county on a big private ranch, but I had it towed back. Thanks for the offer!
I had this same issue a few months ago, it was simply a dirty connector, the 4-pin connector that plugs into the distributor (or the one nearby connector) was causing intermittent starting issues, ,and then it cut off a couple times while driving.
We cleaned the connectors and its been GTG ever since.
Subscribed. Dying to find out what the issue is
Well the shop said it was the ignition switch. Now it starts and runs but my three month old Toyota alternator is only purring out 11.5 volts wtf.
Alternator is piting out 14-16 volts but batter is only getting 12.
Alternator connects DIRECTLY to the battery via the fusible link... REPLACE FUSIBLE LINKS!
... and the SAME fusible link that connects to the alternator ALSO connects to the EFI fuse and your ECU...
cheers,
george.
