Real time help 95 died while driving.
TEXASLAWMAN
TEXAS
Website
www.myspace.com
As the title says my 95 80 series just died while driving down the road. I still have battery power, all fuses look good, she turns over but won't start. My scan gauge showed connecting..... but now shows nothing. Did my computer die? I'm in BFE backwoods with limited cell service. Just plugged the scan gauge into another car and it worked so I'm afraid the computer is fried.
My thing is why would the scan gauge not be getting a signal plenty of power to everything but no signal from computer? Is the computer the black box on the passenger side floorboard wall. Says computer 4 wheel drive control?
secod the efi relay.
3rd EFI relay.
What about fusable link on the battery
What does this look like? Does it only go to the computer? Radio, windows, lights all work. Turn the key starter works just won't start.
Does the check engine light come on with the key in the on position?
No the check engine light does not come on. Seat belt and different lock lights come on for a second, and now low voltage light. When I crank it oil light comes on but no check engine.
EFI relay is toast! Replace that relay & you'll be G2G.
Can someone tell me where power window relays are my flashlight batteries are about to die
Check fusible link. This happened to me. Worse case you can hard wire in place of the link but its dangerous. If it is the link then it blew for a reason. Did you go through water?
Changed the relay with one of window relays no joy. Where is the fusable link what does it look like? No water in the middle of a drought here.
Bundle of three short wires that come directly off the positive battery cable.
Fusible links connect DIRECTLY to the Positive of the Battery - right at the post. They are the 'thin' wires versus the heavier starter motor wire.
They look like in the picture, though I have moved the connector etc into the battery housing area - stock connectors sit on the engine side of the housing.
cheers,
george.
IIRC the fusible link wire with it's own connector in the photo above is the one that supplies power to the ECU.
Main 2.0L fusible link provides power to the EFI 15A fuse.
cheers,
george.
