Read this if you want to successfully rid AHC warning after delete
HGB
In the sand
Very common in Middle East but was told it’s difficult stateside.
Part 1
Part 2
Hope this helps
In part 2 I assume the flashing orange light is the ahc warning. Doesn’t look fixed to me.
Not that I would ever do this, or remove AHC for that matter... One could remove the bulb from the cluster.
So the 'magic' fix is unplug the ahc ecu? Interesting.
Adaptive Front-lighting System. Fancy name for swively headlights.
Probably related due to the height sensors being removed if they have aftermarket suspension.
I know in the LS you can remove the fuse to fix that particular light.
No idea about the LX though.
You are probably right. You can also turn it off via a switch on the dash but I haven’t tried it. I’m guessing it doesn’t give you a blinky light but I’ll check.
Interesting... @AutoCraft Aus care to chime in?
Remove the ecu for the ahc and all the lights stay on, like the headlight adjustment etc. The middle east dont mind driving them around this way.
Been there, tried that.
Thats why we are going a different route :cool:
