I haven't paid close attention to my 80MPH RPM's, but my speedo is dead accurate as compared to GPS speed, with 35/12.50-18 tires and 4.88's. (4 speed, 2002) So whatever your tach reads at an indicated 80 is probably pretty close.
If you do hard stuff offroad you may also want their low range gears for a 25% lower 4Lo, while you had the T-case open.... Cruiser Outfitters 10% underdrive gears for 4H would be perfet for someone who wont go bigger than a 33-33.5in tire
Is there any chance you will ever go to 35s? If so re-gear.
Is your truck high mileage? If so maybe re-gear.
Do you care about going 85mph at a decent RPM with 33s? If so, Do not re-gear.
Are you looking for more low range crawl, hill descent control? If so, re-gear.
Is it very hilly where you live? If so, re-gear.
Edit1: Do you have 33s and still want it lower? If so, re-gear.
Edit2: Do you have an extra grand in you pocket you want to blow? If so, re-gear.
Edit3: Do you feel better about having new stuff mesh with other new stuff? If so, re-gear.
Do you want it all? If so, re-gear.
I did it and I currently run 33s. I would not have done it any other way even if I never planed on running 35s. I am 100% happy with the decision. (note I have a 5 speed). I feel that the lower gearing in the mountains and while pulling stuff is noticeable enough to be worth it. And the best part is that my Diffs have like 1,200 miles on them total.
I have about 1200 miles on my 99 since putting in the Nitro 4.88's....some pulling offroad trailer, some just loaded vehicle, on and off road. I love every single thing about the change! Peppier in town. Far less downshifts on the highway, better hill climbing, transmission seems happier/less confused. No regrets at all. Do the math and you'll see that between 33inch tires and 4.88's my rpms are only up about 5%(using GPS for speed) over stock...that silky V8 doesn't even notice.
If you go 4.88 and 35s you won't need to touch the speedo. I ran 295 70r18 with 4.88s and the speedo was almost perfect.I’ve read through several of these threads and is been mentioned that the Odometer and Speedometer can be calibrated for larger tires.
What is that process and or parts?
I’m likely moving to 35’s and re-gearing to 4.88.
4sp will be dead on. 5sp slightly off.I’m likely moving to 35’s and re-gearing to 4.88.
Listen to this guy, his speedo is absolutely spot on!If you go 4.88 and 35s you won't need to touch the speedo. I ran 295 70r18 with 4.88s and the speedo was almost perfect.
Lol, well it's your speedo now.Listen to this guy, his speedo is absolutely spot on!
My 99 instantly performed better in every way once I went to 4.88sI have a 2000 LC100 V8 under B4 handgun protection with an added weight of almost a ton. Stock F/R bumpers. I could barely reach 40 mph at 1800 rpm. Top speed is 86mph. Should I consider re-gearing to 4.88?
Cheers!
Same hereMy 99 instantly performed better in every way once I went to 4.88s
Looking for a little,advice here. Mainly highway driving, did 100k miles in 3 yrs with my 04. Seems like the rear pinion is wearing Now at 300k miles. I run stock size tires (though 16” from my previous lx470). And predominately run 75mph on the freeways. Looking to go twin 40 gal tanks, though no other mods on vehicle. Would it be prudent to go 4.30’s On the rebuild? Heck, even 4.56? I like the thought of going a little easier on trans/motor and want to hit 500k with this vehicle.
